I am considering a Fronius Gen24 Primo 10.0 (10kva single phase) as AC coupled to Multiplus 48/10000/140-100 etc. Looking at the AC Coupled documents on Victron i see that Primo is 1-8.2kw? Hence is the 10kw Gen24 supported following the 1:1 rule or is the document out of date?
Pretty sure 8.2kw is the largest Primo non-Gen24. The only advantage over the older Primo is better cooling and you can add a battery. The document probably pre-dates the Gen24 release.
