A Not-Victron Victron-System (Fun with ARGB)
This month, I modernized my office PC a bit - and fancy new cases mostly ship with ARGB controllable LEDs and fans.
So, rather than having just some fancy LED animations to choose from, my developer-heart said: Make it indicate something useful :stuck_out_tongue:
Thus, the Victron GX Driven ARGB LED Case was born:
1.) Whenever there is usual ESS-consumption, the fans will indicate the origin of current consumption: From grid (red), from battery (blue), from solar (green). All 3 flows will be mixed in the rotating fan pattern proportional to their share on the total consumption:
Solar-Only Consumption
Solar-Battery-Consumption
2..) The LED bar in the front is - you may have guessed it - indicating the current soc of my system: 27 LEDs, so each LED represents roughly 3.7% soc. Empty part of the battery is illuminated in a dark red, energy containing part in a bright blue.
During charging / discharging the respective part of soc-LEDs are pulsing with the opposite color.
(So, during charging, usually red LEDs will pulse blue, during discharging, usually blue LEDs will pulse red)
Here the pulsing of the “charging soc” is quite visible: 5 LEDs pulsing blue means ~ 18,5% soc per hour and that equals the current chargerate of 12 kW :slightly_smiling_face:
LED bar pulsing
3.) While DESS is intentionally charging, the fan-pattern turns to a red-blue spinner.
DESS Charging
4.) During a DESS scheduled discharge, the fans show a blue/teal spinning pattern.
DESS Discharging
Yes, this ofc. is a highly customized python script and not really a thing that I could share easily by now - but on this, I actually didn’t do all too much on my own: I’ve created the required environment (OpenRGB on my pc, python script that reads gx values from mqtt) - And all the animations were done by claude. I simply described him what I want based on various input examples and how the OpenRGB Controllable sections look like - and he implemented the maths and communication with the OpenRGB-server behind it :slight_smile:
Just sharing cause I love it, and maybe it’s an inspiration for someone to do something similiar as well :slight_smile:
I really like this idea! quite original to show the numbers with a fan :smiley:
