3× MultiPlus-II 48/8000 in ESS Mode 3 – VE.Bus switch “Off” (reg. 33 = 4) over the winter?
I use my 3*MultiPlus II units with a Cerbo AC/AC grid-connected as a battery storage system. In winter, I don’t “need” the battery, because the small amount of PV is just enough for the main battery on the BYD. But when the three inverters are running, they still consume power even when I’m not charging or discharging. Currently, around 60–80 W.
So I was wondering whether I could put them into “winter hibernation” via the VE.Bus. I run ESS Mode 3 and have my own energy management system. I’ve read that setting register 33 = 4 switches the MultiPlus units “off”. Does anyone have experience with this? Are they really off, or in deep standby, so that I can reduce the 60–80 W consumption? Otherwise, the only alternative would be to switch all three off manually at the power switch.
Don’t worry: I’d charge the battery to around 60% SOC beforehand for the winter. Nothing is connected to AC Out.
Thanks for your input!
Best,
JP
If you don’t need anything there, charge the battery and switch everything off.
Hi and thanks,
Sure, that’s always an option, and I may well do that. Since I’ve automated everything here, including forecasts and so on, it’s the “perfectionist” in me that wants the system to automatically detect when it should go into hibernation and do so — and, above all, switch back automatically if the weather unexpectedly stays good for a while in between. That’s a bit at odds with “someone has to go over to the three Victrons, switch them off and on, and unplug the mains cable from the Cerbo GX”… :slight_smile:
Hence the question. If setting register 33 to 4 is “safe” and reduces consumption to a tolerable minimum, then that would at least be an alternative…
Thanks. At its core, you’re absolutely right: of course it works if I switch everything off manually.
You can switch off or limit the PV controllers to keep temperatures within limits.
what do you mean by PV controller? There’s no PV connected to the MultiPlus.
You wrote that you have PV controllers that don’t do much in winter.
Yes, if the temperature is too low, they stop the BYD from charging, and the quiescent currents of the MP drain the battery. The BMS could also shut down.
I have three PV arrays connected to three Fronius inverters. I use the Victrons, AC-AC coupled, with 96 kWh, purely as additional home battery storage. In winter, though, the three arrays produce just enough to cover consumption, or the BYD battery connected to the Fronius stores the surplus neatly. So I’d like to find a way to minimise the Multiplus units’ power consumption, and the register mentioned could be one possible solution.
And yes: I could simply switch them off completely by hand in winter.
