3x Multi RS Solar throttling feed in, why?
It seems the problem is fixed for today at my system:
What did I do? I had switched my AC inverters and the load completely to AC OUT. 20A Limit was there. Now I have switched both back to AC IN (as it was before with the 20A feed-in limitation) but now there is no longer this limitation. I am curious whether this is now permanently the case
