3 Tags Requirement
Having people forced to pick “3 Tags” will end up people choosing random tags, because quite often a matching tag cannot be found - but you HAVE to pick 3 in order to post.
I’d remove or maybe reduce this to one tag - and add a tag “Something Else” to the selection.
Else, the tag system would end up imprecise in a couple of months.
You’re correct, especially for the Q&A section, where many of the other sections tags don’t exist.
We actually also auto tag based on keywords.
Good suggestion, I’ll implement Something Else
Also please report posts you see mis-tagged so I can fix the root cause.
I hope overtime this will diminish to zero as we end up with all the tags we need.
All tags should be available in all categories @alexpescaru - so that’s something I need to fix
Thank you.
Can we also autotag posts with words like sailboat, boat, yacht, marine and similar as marine?
Boat and yacht were already on the auto-tag list. Added the other two.
Yes, I noticed this one was not tagged, as it seems boat keyword did not catch sailboat
Maybe also add catamaran
