3-phase remote configuration
I have 3-phase system with one Multiplus 2 GX and two Multiplus 2. This installation works well, but how I can use VRM portal remote configuration with this installation, if I want change settings later? I can take .rvsc file only from GX device and send it back. How I can send these same settings to two other devices? Have I to do something or will it go automatically to other Multiplus via VE Bus?
Manuals are your friend.
VRM can update 3 phase and parallel systems remotely. There is nothing else you need to do, apart from follow the documented process.
https://www.victronenergy.com/live/vrm_portal:remote-veconfigure
Remote VEConfigure works for both single unit systems as parallel and three phase systems.
Thanks for your reply. I had read manuals but it sounded too easy, because doing it with MK3 adapter it needs more actions.
It only sounds easy because so much work has gone into it. It works. :slight_smile:
