3.81 bug: can't force charging
In Venus 3.81, when I select mode “keep batteries charged” or when I increase the minimal soc, the system doesn’t start charging. I rolled back to 3.80 and there it does work.
Cerbo GX MK2, multi rs Solar 6000, vm-3p75ct
I’m also noticing major communication problems with DESS on multiple sites; I’m going to downgrade.
Keep batteries charged is working for me on V3.81 though I am using a multiplus 2 instead of a RS
Dave
This is a known Issue, but also existing in 3.80.
The Issue only appears under the following conditions:
  • MultiRS
  • DESS idling the battery (!)
  • System has no external MPPTs OR they produce 0W.
  • mode switched to “keep batteries charged”.
This is supposed to be fixed in 3.90~beta6, and will then be backported to (expected) 3.82.
So, if you like you could switch to the beta and verify it’s resolved. The important detail is, that it only happens during scheduled idling.
For the affected versions, switching to “keep batteries charged” is not enough, you need to explicit disable dess as well in this situation.
Jup, the beta seems to fix this issue indeed. Thanks @dognose !
