Now on 3.70~96, and same behavior as below…
I rooted and have been Superuser. With the recent beta upgrade 3.70~91, got the warning about “Inconsistent network security profile.” Instructions say “For the New UI, ‘Change password’ can be used if you want a password.” It was set to weak, so I changed the password. The Inconsistent warning went away.
But now when I open Node Red, it wants a username and password. Tried my email and the password just set as described above. No go. Leave the fields empty, no go. Can’t get into Node Red. A bit of searching and I did a “echo -n “” > /data/conf/vncpassword.txt” from SSH (fortunately, I had keys set up). Rebooted (although more testing proved that unnecessary). Now I again get the Inconsistent warning, but I can get into Node Red again.
Trying (in Remote Console) to change from Superuser to User or User & Installer and it wants a password which I’ve never set and using the one I set as above doesn’t work. But perhaps that’s a different issue, I have had a reason to try since rooting.
In the process, I invited myself under a different email. Registered and got into VRM (different browser, apparently cookies held on the the account when using the same browser). Went through the process and that new account was also a Superuser, even though the account was set to Technician (Remote Console isn’t available if set to User (read only). Again, trying to change in Remote Console to User or User & Installer asks for a password.
