3.70~83 large - Can-Bus Rx/Tx packet counter frozen
On 3.70~83 the Rx/Tx counter gets always stuck on the same count (same count across multiple restarts), but the Can-Bus itself is still functional, i do see data from the battery coming in. Its set to BMS-LV 500kbit/s. Also tried with Node-Red disabled, no change.
Previous version i had on the Cerbo was the official release 3.67 where the counter worked fine.
Seems that you have a MK2 Cerbo.
Wonder if these are not related with the problems the MK2 had with CAN ports and Victron trials to solve them…
Yes, Mk2, HQ2436E2D9Y
This might be related to animation being disabled. The new UI was a bit too eager to disable all dynamic updates. Venus v3.70~86 should correct that.
Yes, counter works with v3.70~86 whether UI animations are on or off
