3.50~8 Cannot set IP of PV inverters manually in GUI 2
The IP cannot be configured in the new Cerbo GX interface (PV Inverters > Add IP address manually).
@frbuceta please confirm the beta version in the topic heading and body. Thanks.
I just updated the header with the version I am using of Venus OS, which is currently the latest.
I just updated to 3.50~9 and the Fronius IP has appeared.
Even so, I recommend to check the IP addition manually because when I have set it, it has not established a connection with the Fronius.
If it happens to me again from now on, I will report back. Thank you for your help.
Will keep an eye on it - thanks!
