@mpvader - Would you be able to advise any more detail on the new Modbus registers outlined in this release?
Many thanks!!
@rprie kindly read the how to post topic in the beta category as well as the guidelines in the change log itself, please do not post comments in the change log as requested.
Often detail can be found on git or even the modbus register, if it has been updated recently, though I am sure you will get a response if it has not. Thank you.
Thanks @nickdb and thanks for splitting the post. There was outlined changes that were not detailed hence the quick note to avoid further confusion.
Unfortunately I cannot find any references as yet for the new registers declared - I’ll figure it out.
–EDIT-- Victron have kindly provided. Thanks!
Glad you came right, if you can, please add the detail to this topic so anyone else with the same query can benefit. Thank you.
