12volt solar CCTV System
Greetings,
I am building a 12 volt solar system to power 4 CCTV cameras and 1 access point. Originally I was going to power these devices individually from a fuse/terminal block to the devices that have 5.5mm jack.
After doing some research I found this 12 volt POE switch that provides 70 watts as a POE budget at 12 volts. I will only be using around half of that. Has anyone here in the community used a device like this one:
Or, am I better off powering the devices with their own power wires? This build will be used in Florida where there is plenty of sunlight.
Thank you for the discussion
Steve
Check these out: ToughSignal Injectors and Switches | MobileMustHave – MobileMustHave.com
Update: Please note, the POE output power varies depending on the input voltage.
