12/12/18 Dc2dc charger problem
Hiya
New 12/12/18 charger installed. Smart altenator 2v wet battery feeding 100ah 12v wet leisure battery. Also smart solar mttp attached.
1st pic is mttp
Thanks
Can someone advise if my settings are correct as the system keeps saying g battery shutdown after 10mins of use.
What does that mean, where do you see this message? Do you mean engine shutdown detected as visble in the last picture? The Orion is off because the starter battery voltage is only 13.1V while you have set the start voltage to 14.0V and the shutdown voltage to 13.1V.
Whether the settings are correct we cant say. Charge voltages depend on the battery that is being charged, so first consult the spec sheet or the manual of the battery. As for the engine shutdown detection, thats on you to check if the voltages match what your alternator is outputting.
The only thing that pops out to me is the output voltage missing on the Orion in the last picture. Check the connection/fuse on the Orion output.
