william-moriarty avatar image
william-moriarty asked
Parallel DC-DC Chargers 30A
Is there an end all be all guide to doing two Orion TR Smart DC to DC 12|12 30 in parallel?
Current setup consists of 1 charger, but when on the phone with Nomadic Cooling they mentioned a few issues with the electrical system. The first one being instead of using the Victron Manual recommended 6 AWG I should be using 1/0.
However I'd like to add another charger into the mix to and curious on best wiring and fusing options.
My first thought of wiring it would be run a single wire from the battery to a 2 stud bus bar and then branch it to each of the chargers. Is this the best idea?
To fuse this I figure a 100 amp fuse on the main cable and then two 60 amp fuses on the split cables?
Please let me know your thoughts.
Orion DC-DC Converters not smart
seahaul avatar image
seahaul answered ·
I would also like to know how to setup multiple dc-dc chargers as mentioned above.
