power-consultant avatar image
power-consultant asked
Consumption Miscalculation of Data in VRM
We experience miscalculated data in the historical Consumption data presented in the VRM dashboard
The system includes:
Cerbo GX (V2.62)
3 Quatro Combi-inverters in 3-Phase (V478)
Smart Shunt
The system is charged by Solar with Smart MPPT's and by an external DC Power supply of ~13KW periodically.
Obviously, when the DC input is on, the consumption calculation is reduced down to zero. In reality, the AC-Loads are almost constantly >5000W.
We assume that it's because the consumption data is read from the SmartShunt & MPPT's but the "Has DC" info is not calculated (as explained in the VRM Portal FAQ).
Question is,
1. is there a way to use the consumption data based on the Combi-Inverter AC-Loads data instead of the Shunt data?
2. Alternatively, is there a way to remove the Historical Data from the VRM dashboard as it is incorrect and confusing the users?
Thank you
VRMBMV Battery Monitordc system
