Paul avatar image
Paul asked
IP67 Unplugged Draws Current
I have an Blue Smart IP67 installed on a boat. The negative lead runs to the negative bus bar which is properly grounded via the engine and prop shaft. When I unplug the charger and disconnect the positive lead then bridge it directly to the battery with a multimeter, it shows 12+ volts and draws around 5 milliamps.
Is this normal? If so, what is going on?
charger
