morty7 avatar image
morty7 asked
Multiplus 1600 Alarm - Solid red LED
Hi all,
My Multiplus 1600 has been working faultlessly for the last 4 and half years, but after putting it on yesterday, it cut out and the alarm led lit solid. Turned it off and on and after a couple of mins did the same thing. No flashing of error code, just straight to alarm on. Tried charging through shoreline connection and that worked fine. Put it to on after an hour of charging and within 20 mins it cuts out again. The manual states error codes for a flashing alarm led, but mine just goes straight to solid on. The voltage at the dc input terminals was 12.6v and I removed both ac input and output connections and it still cuts out. Any help would be greatly appreciated.
error
Paul B avatar image
Paul B answered ·
I sugest that you take this to a Victron Repair dealer with your original invoice and get the unit checked BEFORE the 5 year warranty is up
