kurtsolon avatar image
kurtsolon asked
Octo Connection / Wifi Issues
Team... setting up a new system and upon initial setup I could see the Octo Wifi and was able to pull up the remote access. I then tried to connect the Octo to my local Wifi network. The remote panel froze. I repowered the Octo and now I get one solid green light, one flashing green light and I can't see the Octo Wifi. There doesn't seem to be a bluetooth option either. I'm stuck... is there a way to fully reset with these buttons? How can I get it to broadcast again? Any push would be appreciated.
gx device
kurtsolon answered ·
Second question...
I read that I can restore factory settings on the Venus using this file: venus-data.tgz. Is this the same file used to reset the Octo? Not having an actual user manual for this product is a little frustrating Victron. Seems like this might be my best approach but I'm scared to use the Venus file.
Well... I tried to reset to factory using the venus-data.tgz. The system rebooted with the same one-second flashing green light which means wifi is disabled. The button that is suppose to toggle wifi off/on does nothing. Nor does anything happen when I hold the button for 4 seconds. So, this unit is locked with wifi off and I can't get it to change. Thoughts?
Can you connect the Octo to via LAN to the internet?
Or try to connect a laptop directly to the Octo via LAN.
