48/3000 multiplus-2 GX wont turn on even though dc voltage of 49V is present on input terminals and all components are ok. no burn smell or damage of any kind. new installation.
Is the remote jumper block in place?
If it is removed then the unit will not turn on.
If it powers up then disconnect it and see if everything is then ok, I have had this happen myself a few times (if it does happen again then update the firmware to the latest)
27 People are following this question.
