duane avatar image
duane asked
Docker/Grafana Raspberry Pi
Hello all
I have been playing with Docker/Grafana on Windows and have perfect dashboard for my use. However I dont want to run another windows machine in the motorhome
I purchased a Raspberry Pi 4 and installed as per the instructions on this site but Grafana wont load on port 3000 even though the docker site on port 8088 works perfectly
Has anyone else had this issue?
Thanks for your help
Raspberry Pi
sureshskr avatar image sureshskr commented ·
https://community.victronenergy.com/articles/72317/docker-grafana-dashboards-on-raspberry-pi.html
sureshskr avatar image sureshskr sureshskr commented ·
Please look for my comment
duane avatar image
duane answered ·
For those who have this issue in the future the instructions on the forum are right but the .yaml file you download has a wrong setting in it for a raspberry pi
edit the lines in your yaml file to read
version: '3.4'
services:
server:
image: "victronenergy/venus-docker-server:latest"
ports:
- "8088:8088"
volumes:
- "config-storage:/config"
upnp:
image: "victronenergy/venus-docker-upnp:latest"
network_mode: host
influxdb:
image: "influxdb:1.7"
ports:
- "8086:8086"
volumes:
- "influxdb-storage:/var/lib/influxdb"
environment:
- INFLUXDB_HTTP_LOG_ENABLED=false
graphing:
image: "victronenergy/venus-docker-grafana:2.0.0"
volumes:
- "grafana-storage:/var/lib/grafana"
ports:
- "3000:3000"
volumes:
influxdb-storage:
grafana-storage:
config-storage:
pau1phi11ips avatar image
pau1phi11ips answered ·
Found this post as I couldn't get it to work on a RPi. This also needs changing now:
image: "victronenergy/venus-docker-server:armhf-latest"
See here: https://hub.docker.com/r/victronenergy/venus-docker-server/tags
kevgermany avatar image
kevgermany answered ·
New pi installation using pi os.
More problems in command
docker -compose up --detach
-compose gives error, insert space after -
i.e. docker - compose...
up --detach and up -d equivalent both give errors.
-d gives unknown shorthand flag
--detach gives unknown flag
Implying they're being recognised for the docker command, not the up option
Docker help shows up --detach and -d as valid and equivalent.
Ideas?
