paatrick61 avatar image
paatrick61 asked
venus 2.72 update : my solaredge inverters disappeared
Hi everybody,
my installation has a venus GX attached to 2 multiplus II 48/3000, pylontech batteries and 2 solaredge Se3000 edge (1 master, 1 slaive via RS485).
Everything was working well until the automatic update to v2.72 : the slave solaredge is indicating " remotely turned off " and so not producing any more, I can’t see anymore the solaredge PV inverters on the color control panel eventhough the master solaredge inverter IP address is correctly recognized, but isn’t in the device list.
On the same time, I got a warning from solaredge portal because one of the 2 inverter didn’t report anymore and didn’t produce either.
I tried to backup to v2.71, doesn’t change anything.
any idea ???
thanks for your help
Venus GX - VGX
Kevin Windrem avatar image
Kevin Windrem answered ·
I'd suggest switching back to the version you were running when the system worked. If that version isn't in the stored backup firmware you will need to download it from here:
http://updates.victronenergy.com/feeds/venus/release/images/
Venus GX uses beaglebone
Cerbo GX uses einstein
