mberg avatar image
mberg asked
Wiring Orion Isolated DC-DC remote cable to VE bus BMS
I have two questions regarding wiring of the Orion TR Smart Isolated remote cable. I want to connect the Orion TR Isolated DC-DC charger towards the VE Bus BMS (black and Yellow cable). Can I connect the black ground cable towards the VE-BUS battery - (while grounding of the VE-BUS BMS is arranged via the VE-BUS RJ45 cable, a grounding loop should be avoided?). Question 2: There is no picture of the VE-BUS BMS where to wire the yellow cable (only the mini BMS is shown), I presume that I should connect towards the Charge disconnect (mentioned in the standard picture is "Charger" on the mini-BMS)?
orion-tr smartve.bus bms
