I need help designing my system. How many MPPT do I need to use for a 6KW Pv system 48 V. The panels (18) are 360W each with 47.70V (Voc), Isc 9.56 Amps. Please upload a schematic or wiring diagram if you have one.
Thank you
Thank you
You will need 2 150/75A MPPT's - 6kW at 48v is 125A. 2 off 75A chargers will give 150A total to allow for some spare capacity. At 47.7V Voc, 3 modules can be connected in series to stay in the 150V limit. So there are 3 strings of 3 modules to each charger, you will need 15A fuses in each leg of each string for module protection. Make sure that wiring is of adequate size and type.
28 People are following this question.
