buha avatar image
buha asked
EasyPlus charger making humming noise when SOC near 100%
I have an EasyPlus 12/1600 here which charges a smallish battery. When the EasyPlus is in Storage or Float mode, it makes an annoying noise, a constant hum or buzz, that changes slightly every now and then, but is always well audible.
My questions are:
- Is this a normal thing for the EasyPlus? Could the humming be caused by some bad external wiring or wiring error?
- Is this the same for the other MultiPlus units? Even the ones labelled as "new model, intended to replace the old MultiPlus series"?
- What about the Phoenix Smart IP43 or Skylla IP65? Do they makle any noise during any SOC?
Thanks!
EasyPlus
Jesse avatar image
Jesse answered ·
It's very normal sorry, there are a few threads over these forums discussing this very same hum.
I have a new style multiplus 12/1600 which does the exact same thing at low currents. I don't use it for float, at all. The MPPT's can float quietly, then we just slowly discharge overnight... If I want to float silently I have a crummy old Projecta 25A charger which will do it with no sound!!
