freesurfer avatar image
freesurfer asked
Possible to connect to a SmartSolar MPPT over bluetooth in Venus OS? (RPi3 B+)
I'm playing a bit around with the 2.70 ~14 image on a raspberry pi 3 B+. Bluetooth seems to work because the VictronConnect app can see it as a bluetooth device, and connect.
But I can't seem to find a way to connect my SmartSolar MPPT 150/35 over bluetooth. Is this supposed to be possible? If not, what will I need to make it work? VEDirect USB cable? I also have a Multiplus II 48/3000 and the MK3 USB cable, if that can be used in combination with some other VEDirect cable
Venus OSBluetooth
Hi @Freesurfer,
unfortunately this is not possible via bluetooth.
If you want your MPPT connected to your GX device, you simply use a VE.Direct to USB cable. This should work right away once plugged in.
