Hi, i see since last week that the calculation on the Octo GX are wrong.
the show me on the Batterie -27 Watt, but in the summary consumation 70 Watt.
Multiplus are off, Solar Charger are off.
Any Idea, what happens with the wrong calculation?
Its indicating that you have some other load attached to the battery thats using power as you have other DC systems turned on (this is why the 70w tile is showing), if you dont have any other DC connected then turn this setting OFF.
To help further we would need a full diagram of all connections to help here. as the information provided is not enough to form a full answer
I suspect you have a BMV unit also connected but you dont mention this.
whe Monitor is selected. if you have a BMV then the BMV should be selected.
some screen shots of your settings would also help
27 People are following this question.
