Peter Buijs - NL avatar image
Peter Buijs - NL asked
Cerbo CAN devices on Axiom
On the Axiom (latest Lighthouse 3.13.103)
I get 2x a CAN device
- Unknown n2k device SmartShunt 500A
- Unknown n2k device SmartShunt 500A/50mV 0000501
These supply the Service and Start battery values which works well on the Axiom, I can make a special page to display the values so no problems there.
Just that you are aware that these SmartShunt devices do not show properly on the Axiom Network view.
Product : Unknown ...etc.
Name : The custom name given in Cerbo does not show
Version : No version is shown
cerbo gxVenus GX - VGX
Paul B avatar image
Paul B answered ·
Normally the connection to the AXIOM is done using the Axioms High speed network and connected directly to the cerbos Ethernet port.
then under apps on the Axiom you will see Victron, Access the victron from there.
and a page will pop up showing all the info plus you can see the cerbos pages and access them as well
Peter Buijs - NL avatar image Peter Buijs - NL commented ·
Thanks Paul,
I am aware of the HTML5 App and yes this works well also.
The Victron App on the Axiom does not show the values on the dashboard and you can't customize the display.
I just wanted to point out there was some work to do on the CAN interface side.
