Hi, i'm new to Victron.
What is the best way to connect Multiplus 24/3000/70-50, MPPT SmartSolar 100/50, Venus GX, BMV-700 and VE.net Blue Power panel ?
I'd change the Blue Power Panel for a Venus or Color Control, then read this:
https://www.victronenergy.com/live/ess:start
I will use a Raspberry PI with Venus software instead of Color Control GX, but was just wondering if i can still use the Blue Power Panel somewhere in the system, since solar plant is 30m from the house and the Raspberry Venus will be in the house. I thought i could use the Blue Power Panel in the shed.
The RPi GX will need to stay in the shed. Just the cable lengths to the kit hanging from it makes it impractical to have so far away. Just a single ethernet cable (or EoP, maybe even wifi) to the house router, hence to a laptop or suchlike will give full functionality.
I wouldn't install the Blue Power, The BMV will give you enough local monitoring of the all-important V.
All of it you can monitor/control from the house.
Is this installation totally offgrid?
Yes, its totally off-grid.
How is RPi GX connected to the system ? Via USB Mk3 cable or CAN (Canberrydual V2.1).
How about one RPi GX without display in the shed where the solar is, and one RPi GX with display in the house, connected via local network, for monitoring ?
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
8 People are following this question.
