jbakuwel avatar image
jbakuwel asked
MultiPlus-II, CT, AC current sensor assistant
Hi all,
I need to add a CT to an ESS system using a MultiPlus-II.
The plug has been cut off the CT (wire not long enough). Instead of re-adding the plug and using the designated CT sensor input on the MultiPlus-II, can I also connect the CT to the Aux 1 of the MultiPlus-II and use the "AC current sensor assitant" for that purpose?
Do I also need to enable the "External current sensor connected (see manual)" in VE.Configure? Or is that referring to the designated CT sensor input on the MultiPlus-II only?
Jan
Multiplus-II
bonie-wanda avatar image
bonie-wanda answered ·
My understanding is that the usually blue current sensor that connects with that aux-like endpoint inside the multi does not need a change in settings because the multi treats it like the internal component.
it’s only when you have an externalmeter like the ET112 which that you change the settings.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
