88benjy88 avatar image
88benjy88 asked
Input current limit being exceeded - Multiplus
I have a 48/5000 Multiplus 2 with a BT Smart dongle.
I have set the Max Input Current Limit to 10a via the BT dongle but when I plug the gen set in to top up the batteries it charges at Maximum current which exceeds the generators 3,700w running capacity.
Multiplus-IIinput currentVE.Direct Bluetooth Smart Dongle
Your AC in is not connected.
Your battery is not being charged.
AC out is 189w.
HMmm.
88benjy88 avatar image 88benjy88 klim8skeptic ♦ commented ·
It is connected, the inverter doesn’t have time to evaluate the input current etc before the gen set overloads. The BT dongle interface shows this before the gen set cuts out. If the gen set would hold out another 15 seconds or so I believe the UI would show more details
seb71 avatar image
seb71 answered ·
What if you limit the battery charging current (in Multiplus)?
88benjy88 avatar image 88benjy88 commented ·
That’s the next step but I have to use Ve Configure for that. So another $100 accessory from Victron. I ordered one today.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
