tim22 avatar image
tim22 asked
Ip67 12/25 capacity
The ip67 manual sets the max battery size that can be charged at 225ah. (‘The charger is designed for lead-acid and Li-ion batteries 14-225Ah. Do not use for any other purpose‘). I am currently charging a 200ah lithium bank but would like to go to 300ah. Would this require changing the charger, and if so which charger would be suitable?
Thanks
Tim
charger
jrg avatar image
jrg answered ·
I don't know the exact reason, but it might just be that using a 25A charger to charge a large battery would cause the charger to operate at full capacity for a long period of time. I would hope that Victron designed the charger to operate at full capacity indefinitely, but maybe it would eventually get hot enough to throttle down to a reduced output, taking even longer to charge the battery.
I just bought an IP67 12/25 and I'm planning to use it to charge a 560ah LiFePo4 battery. Although it's not my main charger and would be rare that I'm charging it from full discharge.
