visual avatar image
visual asked
Victron Phoenix 12/50 Resistance values
Hello together,
is it possible to get the values of the Resistors?
my Charger get up to 16,X Volts and like seen on the Picture, there are 3 burned resistors.
i dont know if the resistors are the reason or the impact for the problem so in first step i want to change the burned ones.
Kind regards
chargerbattery system voltage
jack2006 avatar image
jack2006 answered ·
Unfortunatly my charger is a 24V 25A but the control board looks similar to yours however these may be diffferent:- R160 is a 220 Ohm 2W, the resistor you have burnt is 1K ohm 0.6W, both look to be metal film.
Hope this helps, John
