ihanci avatar image
Battery combiner limiting current
I am searching a current limiter between the batteries. I have a battery set including slipring between sets. So I need to protect the slipring. May be I can add a cyrix ct-120a before slipring. I expect that if charging current is over 120A, cyrix ct-120A will limit the charge current to 120A by making voltage low. Is it possible?
charging batteryCyrix Battery CombinerBattery Balancer
