bonie-wanda avatar image
Wind turbine and controller: what is recommended for Multiplus-II/Venus/BlueSolar/Pylontech installation?
I have a small 48v Multiplu—II/BlueSolar/Pylontech/Venus system installation. It works perfectly.
I want to consider a charge aid in the form of a small wind turbine and wind charge controller for those dark rainy windy days. Nothing to big.
Hydro and Wind Power
multiplus-II 48v 3000va;
pylontech 48v 2x 3.5kwh;
bluesolar 150/45 and 150/35
pv panels 8x250w and 4x375w
Paul B avatar image
Paul B answered ·
there are not a lot of wind generator controllers out there and most use some form of resistor as a load dump if they need to reduce the battery charge. so I dont think there will be a recommendation, except to go with whats recommended with the wind gen that you purchase.
the AIRX has its own inbuilt regulator and others have different setups
smueff1970 avatar image
smueff1970 answered ·
have you found a solution ?
Thanks
Thomas
