billrvolz avatar image
billrvolz asked
Victron Connect Change History save type
I have a MPPT 100/20 SmartSolar charge controller. I save the history In Victron Connect before the 30 day limit is reached using BT. The issue I'm having is that if I select one method of saving the data and I don't want to use that method, I can't figure out how to select a different method.
How does one change the method for saving the history in Victron Connect? I'm at version 5.35.
Thanks
VictronConnect
