graham78 avatar image
graham78 asked
Smart bms power source
Hi
I have a smart bms I purchased with my LifePo4 smart batteries. I am not in a position where I can easily return it so need to use it.
my dilemma hangs in the fact that I won’t be using the main poles as intended, should I provide power here (input pole) in the belief that it also provides the power for the unit to function? There are no other ve+ inputs on it so I assume this is a fair place to start.
BMS
Do you mean the Smart BMS CL 12/100?
This take it's supply power from the alternator/starter battery.
I also think this is a bad design.
graham78 avatar image graham78 commented ·
So placing a 12v supply in the input from alternator pole will provide the unit with power and allow it to function?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ graham78 commented ·
Yes, that it is.
