pegasus2009 avatar image
pegasus2009 asked
Canvu update failure. No Firmware Files Found on USB drive
I have tried 3 different makes of USB drives with root directory only. Tried powering unit on and off with and without USB. The CANvu normally has a USB to VE direct plug inserted for an MPPT. I remove it and replace with USB drive. I do not have a way to connect CANvu direct to the internet so doing the USB drive for update. All my other devices update OK. Thanks for any help you can give.
gx device
