I am looking for some information on the “Ignore AC input 1”.
When used within an assistant does it switch the relay highlighted in the schematic attached.
Thanks
Thanks
There is nothing attached.
I think the relay that you mean is the transfer relay and that will open if the programmed parameters are reached. So there is no charging from or passthrough from the grid.
Yes that was the relay. So if Ignore AC input 1 is used to control the relay all AC into the box is switched off?
24 People are following this question.
