I installed Voltage sense wires to my battery bank on the L2 or slave inverter and it does not seem to be seeing the difference in voltage that the batteries are at when under load. It still appear to be getting its info from the inverter cables. Do I need to enable this somewhere or does it need to be connected to the master inverter?
