aghbari avatar image
Victron Battery Balancer
How many balancer(s) do i need if i have 24 volt inverter system with 4 batteries (2 series and 2 parallel)
Battery Balancer
jwfrary avatar image
jwfrary answered ·
Well, it all depends on how fast your trying to charge it.
mom using 1 balancer, on a 280 ah bank at 24v and charging at 60 amps getting about a 0.5% midpoint variation.
I just bumped the charge rate up to 80 amps so I’ll report back when it’s done a cycle.
warwick avatar image
warwick answered ·
One Balancer.
And a midpoint connection between the two banks of the same size as the parallel links between the banks.
Alexandra avatar image
Alexandra answered ·
@Aghbari
If you check out the datasheet
https://www.victronenergy.com/upload/documents/Datasheet-Battery-Balancer-EN.pdf
You can find connection diagrams like this one.
