raymiller avatar image
raymiller asked
Multiplus comparison pdf 07-05-2019 has incorrect specificions for 24/3000/70-32?
Some details of the Mulitplus II comparison pdf dated 07-05-2019 shows different information for 24/3000/70-32 (first column) than in the Multiplus II manual. https://www.victronenergy.com/upload/documents/MultiPlus-II-to-MultiGrid-and-MultiPlus-comparison-EN.pdf
Manual pdf https://www.victronenergy.com/upload/documents/Manual-MultiPlus-II-24V-48V-3k-and-5k-230V-EN-NL-FR-DE-ES-SE-IT.pdf
In particular;
- Maximum efficiency shows 95% (Manual 94%)
- Zero Loads power 11W (Manual 13W)
- Zero Loads in AES mode 7W (Manual 9W)
- Search Mode 2W (Manual 3W)
(I did not do an exhaustive check on all the data only the specifications I was interested in.)
Indications are that the Mulitplus II manual would be correct and the comparison pdf has errors.
If you could please correct the data inconsistencies would be appreciated.
Regards from Australia.
Multiplus-II
