I have 2 temp sensor connected to my Cerbo GX. Input nr2 is unstable, and suddenly goes from ok to "reverse polarity".I have changed the sensors, but it still happens. Get -22 degrees.
I work with temp sensors all day at a battery plant and most of the issues 98% is with the wire our conditions are far worse than being outside I'd check the wire even if nothing is seen
Hope it helps
I have checked the cables, last time it occured I moved the sensor connected at input1 and input2. And the -22 C was still at input2. So I then assumed it could be problem with the Cerbo hardware or firmware. Suddenly, the next day I got message cleared alarm, and it has been ok for about 3 weeks.
15 People are following this question.
