dunnp avatar image
dunnp asked
How to start Docker Victron containers automatically?
I have successfully installed Docker Desktop and Grafana on a Windows PC and have the Victron dashboard working nicely - but still tweaking. Layout below for interest.
Now I'm trying to streamline things.
I created a desktop shortcut to the Grafana dashboard. That works fine - but only if the Docker containers are running first.
At boot-up, Docker loads and runs in the background but to get the Grafana dashboard going, I have to jump into the (hidden) Docker Desktop dashboard and manually click the Start button for the Victron containers each time I start the laptop.
I can't find anywhere in the Docker Desktop to auto-start containers. Can anyone point me in the right direction?
Cheers
Phil
grafana
paulcandelaria avatar image
paulcandelaria answered ·
You can automatically start containers by adding the "restart" option in the docker-compose.yaml file. In this way Docker takes care of restarting the containers as opposed to an OS dependent solution. I have configured the "restart" option for each of my containers in my file, see example below (deployed on a Raspberry PI):
graphing:
container_name: grafana
restart: unless-stopped
image: "victronenergy/venus-docker-grafana:2.0.0"
However, you could also use the following options depending on your requirements:
restart: "no"restart: alwaysrestart: on-failurerestart: unless-stopped
https://docs.docker.com/compose/compose-file/#restart
ajm avatar image
ajm answered ·
Hi Guys
Below docker compose setting will auto start the images.
dunnp avatar image dunnp commented ·
Brilliant - exactly what I need. Works a treat now on my Windows machines.
Thanks.
Phil
Scott Bender avatar image
Scott Bender answered ·
It doesn't look like there currently any way to do this. You would need to use an OS specific method of running the docker-compose command at boot up. What OS are you using?
Using Windows 10 Home with Windows Insider added - effectively W10 Pro from what I can gather.
ianp avatar image
ianp answered ·
Thanks for the great tip Scott. I have just found the same issue with a Raspberry PI 3 installation. The following worked for me:
Add the following to /etc/rc.local before the exit 0.
# Start the Victron influx Grafana package on every boot
cd /home/pi/Downloads
docker-compose up --detach
/home/pi/Downloads is where I saved docker-compose.yaml
I am setting up a remote Victron system with no internet access. Have Venus runing on a Raspberry PI 3, and a second RPI with docker influx and grafana. It’s looking very good.
Ian
Rene Mullie avatar image
Rene Mullie answered ·
This is a functionality which is desirable in almost every setup i guess, might be a good idea to point this out to the Victron moderator to include this in the video/github manual. It took me quite some time to figure it out as I had no experience with Docker at the time.
Agree - should be part of the docker-compose.yaml file as standard.
markus avatar image markus ♦♦ dunnp commented ·
I have just forwarded this to the developers. Thanks!
elvis avatar image
elvis answered ·
Still relevant and helped me today.
Thanks
Ulrich avatar image
Ulrich answered ·
At first I also worked with Docker. Now I have installed all services directly on Windows. For me, this has the advantage that it is easier to administer and that I can update all components myself.
- Influx DB is available for Windows
- Grafana is available for Windows
- I can also help with the implementation of the VRM connection
My Grafana Dashboard: https://www.zoomsoft.de/grafana
elvis avatar image
elvis answered ·
@Ulrich
Indeed, can you assist in setting up a stand alone local database (no vrm, cerbo gx only)? I am currently running the docker version but would like to be able to run without docker and be able update grafana and or influxdb to the latest versions.
Ulrich avatar image Ulrich commented ·
Ok, i will open a new thread and fill it step by step up with installation instructions.
sebashb avatar image
sebashb answered ·
@Ulrich
I'm also trying to run the Victron's Venus Node.js server without docker, as a standalone server, but I'm not having much success. I tried to build the server from this source with
npm install && npm run build
using Node.js 8 but, although there are no errors, when I lunch the server with
npm run start-web
the interface is not completed and most of it is missing.
The only tab that shows the right interface is the security tab. Did you succeed in building and running the server from source?
(If I run the docker container everything shows up correctly)
