icey avatar image
icey asked
MultiPlus 230V 12/3000/120 VE.Bus
Just a question about getting this unit up and running in the most basic form. I have this unit and would like to plug the battery in and get it inverting with no configuration (I.E. Plug and Play) or will I need to have some type of VE.Bus device connected?
When I try to power this unit up I get VE.Bus error 4. I've got a Venus but wanted to get this unit just up and running real quickly without moving my setup around just yet.
Cheers in advance
VE.Bus
icey avatar image icey commented ·
Looks like this unit may have been setup in Parallel mode previously so I might need to factory reset it first...
You have to setup the device for your system (charging current/voltage, discharge voltage).
For that you need a MK3 interface or a GX device with internet connection.
