Today i noticed a widget on the VRM portal under my Lynx Shunt called "Starter battery Voltage".
Is it possible to measure the voltage on a second battery on the Lynx Shunt?
Or is it just for when you have the 712 version?
Kind Regards
ehsab
Kind Regards
ehsab
12 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
