tinybluehouse avatar image
tinybluehouse asked
Battery and 712 show different voltages
While my 200ah 12v smart lithium battery was in absorb I happened to check in on the app and the battery over Bluetooth was showing 13.21v while the bmv was showing 14.21v which is slightly worrying. The shunt is connected to the battery via 70mm2 cable to the 2000kva inverter as per the manual.
BMV Battery MonitorLithium Battery
tinybluehouse avatar image tinybluehouse commented ยท
When I turn the PV off, battery drops to the same voltage on bmv as battery over Bluetooth.
0 Likes 0 ยท
nigelfxs avatar image
nigelfxs answered ยท
Hi @Tinybluehouse
Have you checked the in-line fuse to the BMV-712? It should be a 1A type - not 100mA. There have been some reports of bad readings when fitted with a 100mA fuse.
Itโ€™s 100ma fuse down itโ€™s not that
0 Likes 0 ยท
I totally read that wrong!!! So I need a 1A fuse not the 100ma I have installed. Are they just standard fuses? They look smaller
0 Likes 0 ยท
klim8skeptic avatar image klim8skeptic โ™ฆ tinybluehouse commented ยท
They are an M205 fuse.
20mm long x 5mm diameter.
0 Likes 0 ยท
Victron BMV battery monitors product page
