I have made a couple of battery presets and would like to delete one. I press the blue remove button but nothing happens. I also cannot save changes when I edit a preset.
Is this a bug or am I missing something here?
Thanks for reporting @mahdi and @chrisngrod, I've passed it on to the developers. Apologies in the mean time and it will be fixed in a future update.
EDIT - UPDATE - This problem is now fixed in beta, and will be available in the general release soon. Now here for testing - Download VictronConnect v5.21beta3
Same here can’t edit or delete my own presets?
As Guy Stewart wrote 2 days ago it is a known issue and I guess it will be fixed in the next VictronConnect update.
Same here.
Remove the battery preset is imposible click the button and nothing happens.
FInd the button in the german app is another bug. I only see "Voreinstellungen E..."
I am experiencing the same problem (inability to edit a user defined Battery Preset). To help the developers, here are the details of my config and the problems I am seeing.
Config:
Diagnostics:
Hope that helps.
And a couple of questions:
Thank you
I have downloaded VictronConnect v5.21 Beta 6 to my MacBook and subsequently BlueTooth Interface 2.25 and Charger Firmware 1.50 to my MPPT 100/30s.
Initially I thought that the main problem (inability to create, edit, save and select a new Battery Preset) was fixed but further testing has revealed that this isn’t the case. Here are the details:
Can I respectfully request that before another Beta is released a complete test of all of the Preset “use cases” is carried out. For example: create new Preset, edit and save Preset, select Preset and check that it works, edit and save Preset with different values, select updated Preset and check that new values work, create another new Preset, edit and save this second Preset, select second Preset and check that it works, switch back to first one and check that it works, ditto with the pre-defined presets, remove the second Preset and check that first one is still working. A lot of testing I know but the ongoing problems point to a distinct lack of rigour in the testing regime thus far.
Thank you
17 People are following this question.
