harrison avatar image
harrison asked
First solar build
Just about to start my first solar build on a motorhome conversion. After loads of research I think I’ve nailed it then I find another Victron product that might seem useful but more complex... I’d like to keep my install as simple as possible but totally safe and as efficient as possible.
I currently have 540w (2x270w)
Victron IP22 mains charger 12v 30a
SmartSolar 150v / 35a
Redarc bcdc1240d DC/DC charger (when travelling)
Cotek 12v 1500w inverter
Camper loads (fridge
300ah battery bank
Can I use the lynx power distribution as a common bus bar for all 12v chargers and loads and utilise the fuse inputs to protect the MPPT, Mains charger, dc/dc charger, inverter & loads?....
Or does the system need to start getting a lot more complex?
Thanks for any help,
Help
Rob Fijn avatar image
Rob Fijn answered ·
Hello Harrison, Yes you can do that. You can use this Lynx Power Distribution as a nice solution for your bus bar. Your installation will like good.
Regards, Rob
JohnC avatar image
JohnC answered ·
Hi @Harrison
Victron used the Lynx in their own van install: https://www.victronenergy.com/blog/2019/06/18/the-victron-van-install/
Follow the links for details. Bear in mind that it's a display unit with all the bells'n'whistles, so just remove the bits you don't need.
