dgmar-ni avatar image
dgmar-ni asked
Skylla - TG parallel connection
I wanted to confirm if Skylla-TG 48V models can be connected in parallel for large battery banks. Also I need to know if they can monitored remotely using a GX device.
If they are not able to work in parallel then I need to know which charger device is compatible to work with a Victron system with option to be monitored remotely.
Regards.
battery charging
Paul B avatar image
Paul B answered ·
Yes they can work in Parallel,
they can also be monitored remotey but you would also need a BMV-700 or 702 or 712 Battery monitor connected to the GX unit, this would then show you the TOTAL charge and voltage.
As far as I know you cant monitor individual Chargers
wjf avatar image wjf commented ·
Hey Paul, you seem on to it!! Would appreciate your help. We have 2x 24v500ah banks, and hoping to run 2x Skylla TG 24-100 in parallel. Is this possible? Do we need diodes? Or GX device??
