schubter avatar image
schubter asked
BMS just with CCGX
i am trying to send the ccgx some messages to identify as an bms via can, i believe i wired everything correctly as i can candump from the ccgx and recieve data, if i stop sending data candump stops.
however i am seeing only ERRORFRAMES when dumping.
is it even possible to register as BMS if there is nothing else attached to the ccgx?
BMSCCGX Color Control
schubter answered ·
Hi again,
as there are many ppl watching this, i might aswell share my progress on this.
i've simply forgot to include a SN65HVD230D and after rewiring everything going thru the transceiver, the erroframes i am seeing with candump are now gone and actual data comes in.
now back to coding.
for anyone stumbling over this later, yes its possible to attach a BMS to the CCGX without anything else attached.
thanks for reading
